Can you help me identify this vintage Philco radio
Hi Sue
The last photo you posted is the key...P-941 is the model number.
P equals 1966 model year.
Re: Can you help me identify this vintage Philco radio - by Ron Ramirez - 01-14-2012, 07:23 AM
Philco 91 Tuning Condenser
There are currently 4728 online users. [Complete List]
» 1 Member(s) | 4727 Guest(s)
