Can you help me identify this vintage Philco radio
Thanks--that's what I thought, but I always check before I get rid of (any vintage) item because I have been totally shocked with various items values.
Thanks again for your time!
Sue
Re: Can you help me identify this vintage Philco radio - by suestuff - 01-15-2012, 11:33 AM
Philco 91 Tuning Condenser
