Crosley 148
Hi Eric,
You are looking for a pot around 10-20K It controls the cathode bias and the amount of the antenna that gets into the set.
Crosley 148 - by Eric - 01-18-2012, 06:13 PM
Re: Crosley 148 - by Glenn Roberts - 01-18-2012, 07:27 PM
Re: Crosley 148 - by 7estatdef - 01-18-2012, 08:45 PM
Re: Crosley 148 - by Texasrocker - 01-18-2012, 10:22 PM
Re: Crosley 148 - by Carl Travis - 01-19-2012, 12:19 AM
Re: Crosley 148 - by Eric - 01-19-2012, 01:21 PM
Re: Crosley 148 - by TA Forbes - 01-19-2012, 07:18 PM
There are currently 10581 online users. [Complete List]
» 2 Member(s) | 10579 Guest(s)
