New Acquisition - Philco 38-2670 Question
Hello, picked up a Philco 38-2670 locally for $20 in very good shape. The dial scale is trashed. I looked at Radio Daze and they list two different dial scales for this model, ie. catalog item DS-A366 and DS-A130. Does any one know if there is a difference?
Also, Nostalgia Air does not list a 38-2670 schematic, but do list the 37-2670... are they the same for both 1937 and 1938?
Britt Abbott
Chesapeake, VA
New Acquisition - Philco 38-2670 Question - by wbaradio - 01-19-2012, 08:52 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7426 online users. [Complete List]
» 3 Member(s) | 7423 Guest(s)
