Philco 38-7Cs Identify these parts
Crap. The round deal is not a part 8 the 3500uuf cap that cap in mounted in front of the wafer switch.
My guess #2 or is it 3 whatever is that the round deal is a thermal compensator which I do not see listed on the parts diagram or parts list. In the changes for the set it states that in Run # 3 a new thermal compensator was connected in parallel with compensator # 7A and mounted near resistor #12. The the round doodad is mounted right next to the power resistor #12 in the original photos.
On the right side of your top photo the taller compensator is 7A and has the round thermal compensator in parallel with it, and the other compensator is #7 on the schematic.
List of Changes from Riders: Read the Run 3 details.
[Image: http://i1129.photobucket.com/albums/m501...hanges.jpg]
Then the thermal compensator was replaced with two fixed caps in run 4.
-Keith
Philco 38-7Cs Identify these parts - by mukerjea - 01-17-2012, 10:41 PM
Re: Philco 38-7Cs Identify these parts - by ipwizard - 01-20-2012, 05:37 PM
91H Code 126 Restore
