bakelite plugs of radio Philco 60, 84, 620, 610 ......????
hello again, not the plugs of speaker, i look for the model of plugs of finish of cable of the radio philco annes 30
Philco 60, 610, 620, 84, .....
my email is mauricioarancon@hotmail.com
[No subject] - by Ron Ramirez - 09-19-2006, 08:34 AM
plugs of radio - by Mauricio - 11-05-2006, 03:24 PM
[No subject] - by Ron Ramirez - 11-08-2006, 08:28 PM
thank you, one questions ? - by Mauricio - 11-09-2006, 12:15 PM
[No subject] - by Ron Ramirez - 11-09-2006, 12:58 PM
thank Rom, one questions - by Mauricio - 11-09-2006, 05:50 PM
[No subject] - by Ron Ramirez - 11-09-2006, 07:20 PM
