37-630 I.F. connections?
Cannot find listing for schematic for 37-630 so please post link for schematic for your set. Also state if there is evidence of tampering with the original wiring.
After restoring the power supply with new filter capacitors, replacing all the old wax capacitors, and probably most of the small carbon resistors that have drifted way up, we work backwards from the speaker to the antenna in order to restore the set.
37-630 I.F. connections? - by Dad - 01-21-2012, 03:22 AM
Re: 37-630 I.F. connections? - by codefox1 - 01-21-2012, 12:54 PM
Re: 37-630 I.F. connections? - by Texasrocker - 01-21-2012, 02:07 PM
Re: 37-630 I.F. connections? - by codefox1 - 01-21-2012, 03:31 PM
Re: 37-630 I.F. connections? - by Ron Ramirez - 01-21-2012, 06:06 PM
Re: 37-630 I.F. connections? - by Dad - 01-22-2012, 03:06 AM
91H Code 126 Restore
