37-630 I.F. connections?
This was a revision to the 37-620 and 37-630; documented in Bulletin 251A.
The extra winding is in the 1st IF transformer. The "long black" lead goes to the suppressor grid (pin 5) of the 6K7 IF amplifier tube; the "short black" lead goes to ground.
37-630 I.F. connections? - by Dad - 01-21-2012, 03:22 AM
Re: 37-630 I.F. connections? - by codefox1 - 01-21-2012, 12:54 PM
Re: 37-630 I.F. connections? - by Texasrocker - 01-21-2012, 02:07 PM
Re: 37-630 I.F. connections? - by codefox1 - 01-21-2012, 03:31 PM
Re: 37-630 I.F. connections? - by Ron Ramirez - 01-21-2012, 06:06 PM
Re: 37-630 I.F. connections? - by Dad - 01-22-2012, 03:06 AM
91H Code 126 Restore
