Philco 37-630 shcematic
Hi:
In the Riders index Vol 7 page 57 for the Philco 37-630 ...I think there is a problem the way they illustrated the polarity of both capcitors numbers 62 and 60 (12 mfd and 8 mfd) Should the polarity be the other way around. They have the negative side of both caps going up to the field coil??
I also installed a fuse to this set would a 2 amp slow blow be too much?
Thanks
John
Philco 37-630 shcematic - by Guest - 11-06-2006, 05:15 PM
[No subject] - by Chuck Schwark - 11-06-2006, 10:25 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8760 online users. [Complete List]
» 3 Member(s) | 8757 Guest(s)
