296 Concert Grand Radio & Phonograph
TA Forbes Wrote:I must agree, 1995.00 is a little steep. But they are pretty rare....
I concure the price seems steep, but seeing the production numbers are the same as the Zenith Strats, at least it isn't as steep as one of those. Pictures! Pictures! Pictures! Icon_biggrin
Re: 296 Concert Grand Radio & Phonograph - by Jayce - 01-23-2012, 11:51 PM
Philco 91 Tuning Condenser
