Philco 39-30 Code 121 Wiring and Antenna
The top nut on the IF can normally just supports the top of the coil form. Probably need to remove a pair of nuts under the chassis that mounts the entire IF can.
No loop antenna from the schematic. Uses a flying lead antenna. A 10 ft. 22 ga. wire should do nicely.
http://www.nostalgiaair.org/Resources/289/M0013289.htm
Richard
Re: Philco 39-30 Code 121 Wiring and Antenna - by rghines1 - 01-26-2012, 04:20 PM
91H Code 126 Restore
There are currently 4471 online users. [Complete List]
» 1 Member(s) | 4470 Guest(s)
