Another newbie starts his first Philco a model (41-250)
What you didn't like watching the hickok drive the meter through the right hand side of the case???? I sent Stan an email he should have the consolidated chart fixed by now.
As I was doing the same think to a 41-250 in December (including making tube tester unhappy) I second the tube socket on the XXL tubes being dirty. Mine was DOA till I cleaned the sockets and the radio/phono button on the pushbutton switch board.
As for the power switch I recommend you read this:
http://www.philcoradio.com/notebook/41226.htm
same setup, same switch
John
Las Vegas, NV USA
Philco 91 Tuning Condenser
There are currently 4094 online users. [Complete List]
» 1 Member(s) | 4093 Guest(s)
