bakelite plugs of radio Philco 60, 84, 620, 610 ......????
i have much bakelite plugs of radio of this, but i look for the model of philco exact, because i colector of radio, and i want that my radios has all pieces origianal , incluse the plugs
i have some squematic but in this paper put L-943a, but i have not pictures.
do you know which is the model exasct the radios philco annes 30 ? 620, 60, 37-84 etc
thank you, Maruicio
[No subject] - by Ron Ramirez - 09-19-2006, 08:34 AM
plugs of radio - by Mauricio - 11-05-2006, 03:24 PM
[No subject] - by Ron Ramirez - 11-08-2006, 08:28 PM
thank you, one questions ? - by Mauricio - 11-09-2006, 12:15 PM
[No subject] - by Ron Ramirez - 11-09-2006, 12:58 PM
thank Rom, one questions - by Mauricio - 11-09-2006, 05:50 PM
[No subject] - by Ron Ramirez - 11-09-2006, 07:20 PM
There are currently 8192 online users. [Complete List]
» 2 Member(s) | 8190 Guest(s)
