mod 46 1213 repair
If you run into questions the schematics can't answer be sure to post them here, someone will know the answer.
It's pretty cool that you have your grandmothers radio, many of us don't have a set with a sentimental connection like that. Keep us posted on your progress.
mod 46 1213 repair - by altera6 - 01-26-2012, 04:47 AM
Re: mod 46 1213 repair - by Eliot Ness - 01-26-2012, 09:37 AM
Re: mod 46 1213 repair - by altera6 - 01-26-2012, 09:04 PM
Re: mod 46 1213 repair - by Eliot Ness - 01-29-2012, 09:59 AM
Re: mod 46 1213 repair - by altera6 - 01-31-2012, 05:56 PM
91H Code 126 Restore
