Philco jr. Model 80 - taking apart
Thanks. I thought of just removing a speaker too.
This is what I will do then.
Philco jr. Model 80 - taking apart - by morzh - 01-29-2012, 01:03 PM
Re: Philco jr. Model 80 - taking apart - by morzh - 01-29-2012, 03:57 PM
There are currently 10564 online users. [Complete List]
» 3 Member(s) | 10561 Guest(s)
