Philco 39-7 resto
Ok pull out the 80 tube and measure the AC voltage across the two smaller pins/ holes at the 80 socket. Should see about 500vac. Be careful stick the two probes in the socket hole and then turn the set on. Did you disconnect the old electrolytic caps when you put in the new ones? If not do so.
CF
Her set had the power transformer replaced and the rectifier was replaced with an 80.
Philco 39-7 resto - by numberdevil - 01-17-2012, 10:21 PM
RE: Philco 39-7 resto - by numberdevil - 11-21-2012, 01:31 AM
RE: Philco 39-7 resto - by 7estatdef - 11-21-2012, 06:00 PM
Re: Philco 39-7 resto - by Dave - 01-18-2012, 09:24 AM
Re: Philco 39-7 resto - by numberdevil - 01-18-2012, 10:06 AM
Re: Philco 39-7 resto - by DKinYORKpa - 01-18-2012, 03:00 PM
Re: Philco 39-7 resto - by numberdevil - 01-18-2012, 04:43 PM
Re: Philco 39-7 resto - by 7estatdef - 01-18-2012, 08:23 PM
Re: Philco 39-7 resto - by numberdevil - 01-19-2012, 09:02 PM
Re: Philco 39-7 resto - by ipwizard - 01-20-2012, 02:25 PM
Re: Philco 39-7 resto - by numberdevil - 01-20-2012, 05:24 PM
Re: Philco 39-7 resto - by 7estatdef - 01-20-2012, 07:29 PM
Re: Philco 39-7 resto - by numberdevil - 01-21-2012, 09:38 PM
Re: Philco 39-7 resto - by 7estatdef - 01-23-2012, 01:56 PM
Re: Philco 39-7 resto - by numberdevil - 01-24-2012, 01:41 AM
Re: Philco 39-7 resto - by 7estatdef - 01-24-2012, 08:26 AM
Re: Philco 39-7 resto - by numberdevil - 01-24-2012, 10:44 AM
Re: Philco 39-7 resto - by 7estatdef - 01-24-2012, 02:49 PM
Re: Philco 39-7 resto - by numberdevil - 01-25-2012, 01:33 AM
Re: Philco 39-7 resto - by numberdevil - 01-27-2012, 01:36 AM
Re: Philco 39-7 resto - by 7estatdef - 01-27-2012, 08:08 AM
Re: Philco 39-7 resto - by numberdevil - 01-27-2012, 09:38 AM
Re: Philco 39-7 resto - by numberdevil - 01-28-2012, 05:22 PM
Re: Philco 39-7 resto - by 7estatdef - 01-28-2012, 07:26 PM
Re: Philco 39-7 resto - by numberdevil - 01-29-2012, 02:48 AM
Re: Philco 39-7 resto - by 7estatdef - 01-29-2012, 10:03 AM
Re: Philco 39-7 resto - by numberdevil - 01-29-2012, 11:58 AM
Re: Philco 39-7 resto - by numberdevil - 01-29-2012, 03:56 PM
Re: Philco 39-7 resto - by codefox1 - 01-29-2012, 04:18 PM
Re: Philco 39-7 resto - by 7estatdef - 01-29-2012, 04:50 PM
Re: Philco 39-7 resto - by numberdevil - 01-29-2012, 07:10 PM
Re: Philco 39-7 resto - by 7estatdef - 01-29-2012, 07:37 PM
Re: Philco 39-7 resto - by numberdevil - 01-30-2012, 10:30 AM
Re: Philco 39-7 resto - by 7estatdef - 01-30-2012, 03:40 PM
Re: Philco 39-7 resto - by codefox1 - 01-30-2012, 05:26 PM
Re: Philco 39-7 resto - by 7estatdef - 01-30-2012, 05:29 PM
Re: Philco 39-7 resto - by codefox1 - 01-30-2012, 06:34 PM
Re: Philco 39-7 resto - by numberdevil - 01-31-2012, 01:20 AM
Re: Philco 39-7 resto - by codefox1 - 01-31-2012, 11:58 AM
Re: Philco 39-7 resto - by numberdevil - 01-31-2012, 07:50 PM
Philco 70 antenna lead
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
There are currently 3702 online users. [Complete List]
» 1 Member(s) | 3701 Guest(s)
