1935 38B radio
720 milliamps, according to the service bulletin. A 1-amp-hr battery would last about an hour's worth of playing time.
Your 2-volt "A" battery needs to be beefy. Icon_smile
1935 38B radio - by Chris Drumma - 11-09-2006, 08:54 AM
[No subject] - by Ron Ramirez - 11-09-2006, 09:31 AM
[No subject] - by Chris Drumma - 11-09-2006, 10:12 AM
[No subject] - by Ron Ramirez - 11-09-2006, 10:32 AM
[No subject] - by Bill Hutchinson - 11-09-2006, 09:17 PM
[No subject] - by Chuck Schwark - 11-09-2006, 10:24 PM
[No subject] - by Bill Hutchinson - 11-09-2006, 11:08 PM
[No subject] - by Ron Ramirez - 11-10-2006, 11:05 AM
[No subject] - by Ron Ramirez - 11-10-2006, 11:11 PM
There are currently 4032 online users. [Complete List]
» 1 Member(s) | 4031 Guest(s)
