need help with my philcl 42-1013
magicclocks Wrote:My phono works great. No radio at all I used to have am and fm intermittently but I used it a little too much before I started to recap it. now I have no reception at all . i have resisters ordered too. Could someone point me in the right direction.the only electrolitic caps I haven't replaced yet are the two 8 mfd caps mounted on the chassis .those are coming could the if transformers be blown or what. I really don't know what to do next
I just finished one of these.
Some of those caps are a real bear to get to.
My radio had the 1012 chassis.Tranny was fried,so I found a cheap 1013 chassis and rebuilt that one.
My record changer need some work though.Beam of light changer.
Have fun with this project.
I have a few parts left with the 1012 chassis if you need anything.
murf
need help with my philcl 42-1013 - by magicclocks - 01-05-2012, 12:12 AM
Re: need help with my philcl 42-1013 - by murf - 01-29-2012, 11:36 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6931 online users. [Complete List]
» 1 Member(s) | 6930 Guest(s)
