My New Marconi
I made the trip of 200 miles to pick up this Marconi model 117
It need a grill cloth and knobs[which I have]. The 6U5 is quite bright and the owner said it works but I will do a recap. I think I will leave the finish alone except do some work on the top. I used to own one of these but this time it's a keeper because my last one sounded very good. It has nine tubes. I just love the large glass dial,which is very impressive in the dark.[Image: http://i318.photobucket.com/albums/mm405...Medium.jpg][Image: http://i318.photobucket.com/albums/mm405...Medium.jpg]
   Living in Calgary Alberta
My New Marconi - by Dan Walker - 01-30-2012, 01:37 AM
Re: My New Marconi - by Texasrocker - 01-30-2012, 11:52 PM
Re: My New Marconi - by Arran - 02-09-2012, 01:15 AM
Re: My New Marconi - by Dan Walker - 02-12-2012, 05:39 PM
Re: My New Marconi - by Ron Ramirez - 02-12-2012, 07:35 PM
Re: My New Marconi - by Arran - 02-12-2012, 10:50 PM
There are currently 8509 online users. [Complete List]
» 1 Member(s) | 8508 Guest(s)
