1935 38B radio
Building a suitable high current power supply can be a challenge. Some that I've built have worked quite well, but the voltage regulator can run quite hot.
I've built some around the high current version of the LM317 adjustable regulator that comes in a TO-3 package (don't remember the exact number offhand).
Anyone have a good high current power supply circuit they'd like to share?
Bill
Sent from my Pentium II on the AT&T Dial Network
1935 38B radio - by Chris Drumma - 11-09-2006, 08:54 AM
[No subject] - by Ron Ramirez - 11-09-2006, 09:31 AM
[No subject] - by Chris Drumma - 11-09-2006, 10:12 AM
[No subject] - by Ron Ramirez - 11-09-2006, 10:32 AM
[No subject] - by Bill Hutchinson - 11-09-2006, 09:17 PM
[No subject] - by Chuck Schwark - 11-09-2006, 10:24 PM
[No subject] - by Bill Hutchinson - 11-09-2006, 11:08 PM
[No subject] - by Ron Ramirez - 11-10-2006, 11:05 AM
[No subject] - by Ron Ramirez - 11-10-2006, 11:11 PM
