38-38 Battery Problem
Bill,
I have a 38-38 myself here that is rebuilt. I recall the A battery had a socket built into it. The dry battery if used was part number 41-8011 and had a socket for a 1F1 ballast tube which dropped the voltage to the required 2 volts. I think the 1F1 was a four prong tube. A few years earlier, the Philco 38 had a socket which was usually jumped out but could use a type 6 ballast. It was on the chassis. I think the 1F1 was similar in specifications. I would be interested to know if you have plans to make more.
Fred
38-38 Battery Problem - by batterymaker - 11-09-2006, 10:57 PM
[No subject] - by Fred R - 11-09-2006, 11:11 PM
[No subject] - by batterymaker - 11-10-2006, 10:04 AM
[No subject] - by Fred R - 11-10-2006, 02:42 PM
[No subject] - by batterymaker - 11-10-2006, 10:19 PM
[No subject] - by batterymaker - 11-22-2006, 09:45 PM
[No subject] - by batterymaker - 12-14-2006, 01:49 PM
[No subject] - by Chuck Schwark - 12-14-2006, 02:32 PM
[No subject] - by Terry Burns - 12-14-2006, 04:37 PM
[No subject] - by Chris Drumma - 12-15-2006, 09:17 AM
[No subject] - by batterymaker - 12-15-2006, 11:52 AM
