Philco 87 Highboy
I am getting ready to rebuild the condenser block and I have a couple of questions. Which would be better to use for the filters, Electrolytes or metalized film capacitors, and at what voltage?
Thanks
Skip
Philco 87 Highboy - by Skip - 01-30-2012, 07:50 PM
Re: Philco 87 Highboy - by 7estatdef - 01-30-2012, 10:32 PM
Re: Philco 87 Highboy - by Skip - 01-31-2012, 08:45 AM
Re: Philco 87 Highboy - by Chuck Schwark - 01-31-2012, 02:13 PM
Re: Philco 87 Highboy - by TA Forbes - 01-31-2012, 02:35 PM
Re: Philco 87 Highboy - by Skip - 02-15-2012, 09:42 PM
Re: Philco 87 Highboy - by 7estatdef - 02-16-2012, 08:29 AM
Re: Philco 87 Highboy - by Skip - 02-16-2012, 02:44 PM
The speaker table error?
Philco 70 antenna lead
