38-38 Battery Problem
On the BC batteries? Sure.
It's a big'n, though. Stands close to a foot high, almost as wide.
So, just want to make sure, the 1F1 normally was installed on the chassis, not within the battery itself?
I ask that because I've seen some obscure Zenith battery data that had the ballasts installed in the battery itself--which I thought was rather odd.
Bill
38-38 Battery Problem - by batterymaker - 11-09-2006, 10:57 PM
[No subject] - by Fred R - 11-09-2006, 11:11 PM
[No subject] - by batterymaker - 11-10-2006, 10:04 AM
[No subject] - by Fred R - 11-10-2006, 02:42 PM
[No subject] - by batterymaker - 11-10-2006, 10:19 PM
[No subject] - by batterymaker - 11-22-2006, 09:45 PM
[No subject] - by batterymaker - 12-14-2006, 01:49 PM
[No subject] - by Chuck Schwark - 12-14-2006, 02:32 PM
[No subject] - by Terry Burns - 12-14-2006, 04:37 PM
[No subject] - by Chris Drumma - 12-15-2006, 09:17 AM
[No subject] - by batterymaker - 12-15-2006, 11:52 AM
