Zenith 7S363
Picked up my second project at a second hand store a few days ago for a song because the cabinet was so dirty w/ candle wax all over it. I removed the chassis, speaker, and grille cloth. I ordered the new caps and stripped the cabinet, and the glue is drying on a new piece of walnut veneer... Has anyone worked on one of these? Any gotchas?
One cannot forbid people to be idiots....all one can do is try not to be one. -Morzh
Zenith 7S363 - by LedHed - 02-01-2012, 09:13 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 02:08 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 03:13 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 03:46 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 05:34 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 05:50 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 06:07 PM
Re: Zenith 7S363 - by Jbaker - 02-02-2012, 10:38 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:14 AM
Re: Zenith 7S363 - by Jbaker - 02-03-2012, 12:27 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:43 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 08:36 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 09:30 AM
Re: Zenith 7S363 - by Eliot Ness - 02-03-2012, 10:08 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 10:27 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 11:41 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 11:44 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:29 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:53 PM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 01:01 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 04:47 PM
Re: Zenith 7S363 - by Jbaker - 02-03-2012, 09:45 PM
Re: Zenith 7S363 - by LedHed - 02-14-2012, 01:30 PM
Re: Zenith 7S363 - by LedHed - 02-14-2012, 01:35 PM
There are currently 7165 online users. [Complete List]
» 1 Member(s) | 7164 Guest(s)
