Zenith 7S363
Great Northern Antique Radios (Alan Jesperson) has the reproduction tabs and pushbuttons:
http://www.alanjesperson.com/gn_repro.htm
K60 is the part# for the "Long hook push button stations"
K61 is the part# for the "Short hook push button tone"
K62-1 is the part# for the "Triangular station indicator tab"
K63-1 is the part# for the "Triangular tone indicator tab"
Good luck!
Zenith 7S363 - by LedHed - 02-01-2012, 09:13 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 02:08 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 03:13 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 03:46 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 05:34 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 05:50 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 06:07 PM
Re: Zenith 7S363 - by Jbaker - 02-02-2012, 10:38 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:14 AM
Re: Zenith 7S363 - by Jbaker - 02-03-2012, 12:27 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:43 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 08:36 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 09:30 AM
Re: Zenith 7S363 - by Eliot Ness - 02-03-2012, 10:08 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 10:27 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 11:41 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 11:44 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:29 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:53 PM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 01:01 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 04:47 PM
Re: Zenith 7S363 - by Jbaker - 02-03-2012, 09:45 PM
Re: Zenith 7S363 - by LedHed - 02-14-2012, 01:30 PM
Re: Zenith 7S363 - by LedHed - 02-14-2012, 01:35 PM
