Zenith 7S363
Thanks Mike, I tried to clean the cabinet up but the scratches were pretty bad and there was a nasty water ring on top plus some missing veneer. That's why I decided to strip it all down. On the upside, it was mostly intact and the veneer itself wasn't too badly gouged. It's been neat to see the wood come to life.
One cannot forbid people to be idiots....all one can do is try not to be one. -Morzh
Zenith 7S363 - by LedHed - 02-01-2012, 09:13 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 02:08 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 03:13 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 03:46 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 05:34 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 05:50 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 06:07 PM
Re: Zenith 7S363 - by Jbaker - 02-02-2012, 10:38 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:14 AM
Re: Zenith 7S363 - by Jbaker - 02-03-2012, 12:27 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:43 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 08:36 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 09:30 AM
Re: Zenith 7S363 - by Eliot Ness - 02-03-2012, 10:08 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 10:27 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 11:41 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 11:44 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:29 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:53 PM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 01:01 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 04:47 PM
Re: Zenith 7S363 - by Jbaker - 02-03-2012, 09:45 PM
Re: Zenith 7S363 - by LedHed - 02-14-2012, 01:30 PM
Re: Zenith 7S363 - by LedHed - 02-14-2012, 01:35 PM
There are currently 10476 online users. [Complete List]
» 2 Member(s) | 10474 Guest(s)
