Zenith 7S363
Photo Time! Here is the original finish
<!-- m --><a class="postlink" href="http://i1267.photobucket.com/albums/jj541/Ledhedsymbols/1939%20Zenith/IMG_1881.jpg">http://i1267.photobucket.com/albums/jj5 ... G_1881.jpg</a><!-- m -->
<!-- m --><a class="postlink" href="http://i1267.photobucket.com/albums/jj541/Ledhedsymbols/1939%20Zenith/IMG_1880.jpg">http://i1267.photobucket.com/albums/jj5 ... G_1880.jpg</a><!-- m -->
<!-- m --><a class="postlink" href="http://i1267.photobucket.com/albums/jj541/Ledhedsymbols/1939%20Zenith/IMG_1879.jpg">http://i1267.photobucket.com/albums/jj5 ... G_1879.jpg</a><!-- m -->
<!-- m --><a class="postlink" href="http://i1267.photobucket.com/albums/jj541/Ledhedsymbols/1939%20Zenith/IMG_1878.jpg">http://i1267.photobucket.com/albums/jj5 ... G_1878.jpg</a><!-- m -->
After stripping the old finish
<!-- m --><a class="postlink" href="http://i1267.photobucket.com/albums/jj541/Ledhedsymbols/1939%20Zenith/IMAG0128.jpg">http://i1267.photobucket.com/albums/jj5 ... AG0128.jpg</a><!-- m -->
My shop helper and I prepping the new veneer section.
<!-- m --><a class="postlink" href="http://i1267.photobucket.com/albums/jj541/Ledhedsymbols/1939%20Zenith/IMG_1885.jpg">http://i1267.photobucket.com/albums/jj5 ... G_1885.jpg</a><!-- m -->
One cannot forbid people to be idiots....all one can do is try not to be one. -Morzh
Zenith 7S363 - by LedHed - 02-01-2012, 09:13 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 02:08 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 03:13 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 03:46 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 05:34 PM
RE: Zenith 7S363 - by murf - 12-26-2012, 05:50 PM
RE: Zenith 7S363 - by LedHed - 12-26-2012, 06:07 PM
Re: Zenith 7S363 - by Jbaker - 02-02-2012, 10:38 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:14 AM
Re: Zenith 7S363 - by Jbaker - 02-03-2012, 12:27 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:43 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 08:36 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 09:30 AM
Re: Zenith 7S363 - by Eliot Ness - 02-03-2012, 10:08 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 10:27 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 11:41 AM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 11:44 AM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:29 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 12:53 PM
Re: Zenith 7S363 - by Michael Dennis - 02-03-2012, 01:01 PM
Re: Zenith 7S363 - by LedHed - 02-03-2012, 04:47 PM
Re: Zenith 7S363 - by Jbaker - 02-03-2012, 09:45 PM
Re: Zenith 7S363 - by LedHed - 02-14-2012, 01:30 PM
Re: Zenith 7S363 - by LedHed - 02-14-2012, 01:35 PM
