Philco's oldest FM set?
What is Philco's oldest FM table and console radio they made that received the modern FM frequencies?
-Keith
Philco's oldest FM set? - by ipwizard - 02-03-2012, 04:56 PM
Re: Philco's oldest FM set? - by Ron Ramirez - 02-03-2012, 07:36 PM
Re: Philco's oldest FM set? - by Jbaker - 02-04-2012, 01:19 AM
Re: Philco's oldest FM set? - by ipwizard - 02-06-2012, 02:28 PM
Philco 91 Tuning Condenser
There are currently 5893 online users. [Complete List]
» 3 Member(s) | 5890 Guest(s)
