38-7CS Antenna
Good Morning from the West Coast!
What was the original antenna on this one like? When I got it there was a large ball of uncoated, stiff wire in the space under the chassis! seemed to work ok for AM, but I'm pretty sure that the factory didn't put it there.
Jim
38-7CS Antenna - by Guest - 10-29-2005, 11:56 AM
[No subject] - by Ron Ramirez - 10-29-2005, 03:31 PM
[No subject] - by Guest - 10-30-2005, 12:12 AM
