Different Philco Resistor Part Number
Schematic here
http://www.nostalgiaair.org/PagesByModel...013702.pdf
R14 1 watt, R15 2 watts, all others in the set 1/2 watt.
If I were recapping the set, I'd replace 'em all, easy and cheap, makes a big difference in the end.
Re: Different Philco Resistor Part Number - by codefox1 - 02-04-2012, 03:55 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7111 online users. [Complete List]
» 2 Member(s) | 7109 Guest(s)
