Picked up a nice 38-7 the other day
I saw one of those 38-7XX models at an auction a few years ago (or the Canadian version), I don't think that I bid on it, I think that I bid on a DeForest Crosley and a Sparton console instead since they had nicer looking cabinets and were early 30s vintage. At that point I stopped going after consoles that had less then 7 or 8 tubes in the chassis.
I had an idea regarding the grille cloth problem with these sets. The thing to look for is some pin striped fabric of a suitable colour, or something that could be dyed a suitable colour, then stitch two pieces of it together so the pin stripes are at a 45 degree angle (or whatever it was) with the seam down the center. Obviously it would not be as good as the reproduction cloth is but still better then nothing.
RE: Picked up a nice 38-7 the other day - by TimC - 03-08-2012, 08:38 AM
Re: Picked up a nice 38-7 the other day - by Arran - 02-04-2012, 09:44 PM
Philco 91 Tuning Condenser
There are currently 5079 online users. [Complete List]
» 3 Member(s) | 5076 Guest(s)
