Philco 90 High Resistance Antenna Coil?
So just for laughs take your ohm meter and measure the resistance from chassis ground and the ANT post. What do you get?
The set doesn't care where you connect the antenna. Sometimes you can get some 60cy modulation mixed in with the incoming signal if there isn't a ground return for the grid.
Philco 90 High Resistance Antenna Coil? - by Joe - 02-04-2012, 02:39 PM
Re: Philco 90 High Resistance Antenna Coil? - by 7estatdef - 02-04-2012, 11:15 PM
91H Code 126 Restore
There are currently 2564 online users. [Complete List]
» 2 Member(s) | 2562 Guest(s)
