37-610 IF Can covers
Sorry, no ability to post a picture at this point. Do have the clips securing it to the chassis off, and cannot see much of the bottom. I suppose that I will have to desolder its connections and then try to see what the problem is unless someone else has any ideas.
Thanks though, Codefox, for the rapid reply.
Richard
Richard
37-610 IF Can covers - by RGallahue - 02-05-2012, 01:55 PM
Re: 37-610 IF Can covers - by codefox1 - 02-05-2012, 03:17 PM
Re: 37-610 IF Can covers - by RGallahue - 02-05-2012, 03:55 PM
Re: 37-610 IF Can covers - by Ron Ramirez - 02-05-2012, 06:12 PM
Re: 37-610 IF Can covers - by RichardG - 02-07-2012, 08:08 PM
Re: 37-610 IF Can covers - by codefox1 - 02-08-2012, 11:45 AM
Re: 37-610 IF Can covers - by RGallahue - 02-08-2012, 09:11 PM
Re: 37-610 IF Can covers - by codefox1 - 02-08-2012, 11:25 PM
91H Code 126 Restore
