Take a look! Model 144B Cathedral
WOW !!!! Icon_clap Whoever did the refinish did an outstanding job !!!! Looks like it just rolled off of the assembly line. Another beauty Ron !!!! Alan
Re: Take a look! Model 144B Cathedral - by TimC - 05-19-2010, 09:02 AM
Re: Take a look! Model 144B Cathedral - by vinzer - 05-19-2010, 12:25 PM
Re: Take a look! Model 144B Cathedral - by hotrod - 05-19-2010, 05:44 PM
Re: Take a look! Model 144B Cathedral - by denver - 05-19-2010, 07:29 PM
Re: Take a look! Model 144B Cathedral - by Uffda - 05-20-2010, 03:12 PM
Re: Take a look! Model 144B Cathedral - by Arran - 01-31-2012, 02:35 AM
Re: Take a look! Model 144B Cathedral - by Jayce - 01-31-2012, 11:51 AM
Re: Take a look! Model 144B Cathedral - by kg4wpt - 02-05-2012, 04:33 PM
Philco 91 Tuning Condenser
There are currently 5837 online users. [Complete List]
» 2 Member(s) | 5835 Guest(s)
