Advice for a beginner
winkydink Wrote:Any idea where I can purchase a polarized plug with a inline fuse ?'
Let's say that I am working on a 48-200 on the following schematic where would the "polarized" lead goto (i.e. where is the ground on the radio)
http://www.nostalgiaair.org/resources/627/M0013627.htm
The metal chassis is ground, but not connected to either side of the AC line.
I would rewire a set like this slightly so that switch is on the hot side going to pin #1 on the 35Y4 rectifier. Then, the neutral side of the plug goes to the 'B-" buss.
I usually hide a small fuse somewhere under the chassis rather than use one in the power cord.
Advice for a beginner - by winkydink - 01-23-2012, 09:51 AM
Re: Advice for a beginner - by imacdaddy757 - 01-25-2012, 07:42 PM
Re: Advice for a beginner - by dan mauro - 01-26-2012, 11:24 AM
Re: Advice for a beginner - by 37silverstreak - 01-27-2012, 01:21 PM
Re: Advice for a beginner - by imacdaddy757 - 01-28-2012, 06:33 AM
Re: Advice for a beginner - by dan mauro - 01-30-2012, 12:20 PM
Re: Advice for a beginner - by winkydink - 02-01-2012, 09:22 AM
Re: Advice for a beginner - by Dave - 02-01-2012, 07:53 PM
Re: Advice for a beginner - by winkydink - 02-02-2012, 03:15 PM
Re: Advice for a beginner - by imacdaddy757 - 02-02-2012, 07:49 PM
Re: Advice for a beginner - by winkydink - 02-02-2012, 09:17 PM
Re: Advice for a beginner - by winkydink - 02-03-2012, 10:50 AM
Re: Advice for a beginner - by imacdaddy757 - 02-06-2012, 05:10 AM
Re: Advice for a beginner - by Bob Andersen - 02-06-2012, 05:25 PM
Re: Advice for a beginner - by codefox1 - 02-06-2012, 05:37 PM
91H Code 126 Restore
