restuffing electrolythics: how do you remove the top cap?
Hi,
In the Philco 80 there are the Sprague can caps that have the top caps that are beaded around the cylinder. Sort of like a beer bottle cap, only smooth, with no ruffles for the opener.
Is there any way to lift the caps without damaging them? I'd like to avoid cutting and to just press the cap out, and the glue it in place when done re-stuffing.
Maybe someone tried that already.
Mike.
restuffing electrolythics: how do you remove the top cap? - by morzh - 02-06-2012, 06:43 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7649 online users. [Complete List]
» 3 Member(s) | 7646 Guest(s)
