116X electrolytic voltage ratings
I want to order parts to redo my 1936 116X but the parts list does not give voltages for the electrolytics. It's very difficult to read the cans that are on the chassis but it appears that one says 8mfd 475v and the other says 8mfd 500v. Could that be correct? I've never run into electrolytics with voltages that high before and want to be sure of what I need. My suppliers electrolytics only go up to 450v. The other cans are unreadable. I'm hoping someone has done a 116X before and may have the information I need. A complete list of the electrolytics, with voltages, would be wonderful. Icon_biggrin
Larry
116X electrolytic voltage ratings - by rocketeer - 02-06-2012, 08:29 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7737 online users. [Complete List]
» 3 Member(s) | 7734 Guest(s)
