restuffing electrolythics: how do you remove the top cap?
Thanks Kevin
Yes, I saw the post - it's been here awhile. It's a great way; I just wanted to know if there's another way.
I guess I will go with it.
Re: restuffing electrolythics: how do you remove the top cap - by morzh - 02-06-2012, 09:58 PM
91H Code 126 Restore
