Cleaning aluminum electrolytics in Philco 80 jr.
Sigh...
http://www.philcoradio.com/phorum/showth...p?tid=3126
Quote:II. Multiple threads on the same subject not allowed.
When you start a thread, please keep the discussion within the same thread.
Example: "Philco 90 broken"
After you've started that thread, please do not start another thread on "Philco 90 bad resistor" if it is the same Philco 90 being discussed in the original thread. Give others a chance to respond to your questions rather than asking them again in a new thread - please be patient.
These sort of threads will be immediately deleted, to keep clutter to a minimum.
Please cooperate with me in keeping one thread in the same place rather than scattering it around.
Please continue the discussion in the original thread.
http://www.philcoradio.com/phorum/showth...p?tid=4263
Re: Cleaning aluminum electrolytics in Philco 80 jr. - by Ron Ramirez - 02-08-2012, 11:50 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7784 online users. [Complete List]
» 2 Member(s) | 7782 Guest(s)
