Some Philco 70 questions/ANSWERED
Probably.
Philco issued two different Service Bulletins for the early 70. The earlier one, as I recall, had additional mica capacitors across many, perhaps all, of the trimmer condensers; the later "early" version did not.
You should order the complete package from Chuck, he should have both versions of the early 70 service info. And the nominal cost is well worth it for what you receive.
http://www.philcorepairbench.com/schematics.htm
Some Philco 70 questions/ANSWERED - by DKinYORKpa - 01-01-2012, 03:57 PM
Re: Some Philco 70 questions - by 37silverstreak - 01-01-2012, 04:55 PM
Re: Some Philco 70 questions - by Carl Travis - 01-01-2012, 05:19 PM
Re: Some Philco 70 questions - by DKinYORKpa - 01-01-2012, 06:28 PM
Re: Some Philco 70 questions - by 37silverstreak - 01-01-2012, 06:56 PM
Re: Some Philco 70 questions - by TA Forbes - 01-01-2012, 09:01 PM
Re: Some Philco 70 questions - by 7estatdef - 01-02-2012, 12:41 PM
Re: Some Philco 70 questions - by ipwizard - 01-05-2012, 06:37 PM
Re: Some Philco 70 questions - by DKinYORKpa - 01-29-2012, 05:01 PM
Re: Some Philco 70 questions/New question/ANYONE? - by Ron Ramirez - 02-08-2012, 09:15 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7095 online users. [Complete List]
» 2 Member(s) | 7093 Guest(s)
