Sparks Withington
With regards to the Sparton, not that it's the most esthetically appealing option but if the type 183s are bad or missing I have read that a series string TV tube called a 5V6 can be used as an substitute with an adapter.
Sparks Withington - by squeeker7 - 02-07-2012, 12:22 PM
Re: Sparks Withington - by squeeker7 - 02-07-2012, 01:06 PM
Re: Sparks Withington - by TA Forbes - 02-07-2012, 01:20 PM
Re: Sparks Withington - by squeeker7 - 02-07-2012, 02:17 PM
Re: Sparks Withington - by Bob Andersen - 02-08-2012, 12:54 AM
Re: Sparks Withington - by squeeker7 - 02-08-2012, 09:31 AM
Re: Sparks Withington - by Bob Andersen - 02-08-2012, 06:44 PM
Re: Sparks Withington - by Arran - 02-09-2012, 12:56 AM
Re: Sparks Withington - by squeeker7 - 02-09-2012, 08:10 AM
There are currently 10582 online users. [Complete List]
» 2 Member(s) | 10580 Guest(s)
