restuffing electrolythics: how do you remove the top cap?
I would use a heat gun or bake it in an old toaster oven to melt the innards out, not too high maybe 250 F or so, propane torch is a little too hot and tar does burn if you get it hot enough.
Re: restuffing electrolythics: how do you remove the top cap - by Arran - 02-09-2012, 09:28 PM
91H Code 126 Restore
