Correct power/volume knobs for a 116X?
Hello, Larry: they are the same black knobs found on nearly all of the 1936 models. Pretty common.
Re: Correct power/volume knobs for a 116X? - by TA Forbes - 02-09-2012, 11:39 PM
There are currently 6927 online users. [Complete List]
» 4 Member(s) | 6923 Guest(s)
AvatarAvatarAvatarAvatar
