Philco 41-290 audio output and speaker information requested
Chuck,
Many thanks for the information! I'll pull the chassis out of the case to see if it has the audio transformer in it.
Any idea what I could use to sub the field coil and the 400hz humbucking choke? I have a goodly supply of chokes on hand I could possibly use, but would have to check their ratings.
Very Best Regards,
Joe Cro N3IBX
[No subject] - by Chuck Schwark - 11-12-2006, 09:53 PM
[No subject] - by Guest - 11-12-2006, 11:52 PM
[No subject] - by Chuck Schwark - 11-13-2006, 10:25 AM
[No subject] - by Guest - 11-13-2006, 05:48 PM
[No subject] - by Chuck Schwark - 11-13-2006, 06:20 PM
[No subject] - by Guest - 11-13-2006, 07:18 PM
