Philco 39-40 Voltage Readings Request
Pull the 84 and measure the AC from pins 2 then 3 to the center tap of the HV winding. If they are very close, probably OK. With 84 removed do rest of tubes light up OK and transformer not getting hot? Maybe still OK, but filter capacitors at very least must be changed.
Re: Philco 39-40 Voltage Readings Request - by codefox1 - 02-10-2012, 12:12 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7209 online users. [Complete List]
» 3 Member(s) | 7206 Guest(s)
