Philco 38-7 dial lamp
How do I get to the dial lamp in a Philco 38-7? I do not see any screws holding the brass bezel on. It looks like the brass bezel should turn and then come off; however, it just turns about a 1/4 inch an nothing.
Philco 38-7 dial lamp - by joejoe - 02-11-2012, 03:18 AM
Re: Philco 38-7 dial lamp - by rghines1 - 02-16-2012, 11:24 AM
RE: Philco 38-7 dial lamp - by joejoe - 02-27-2012, 01:41 AM
RE: Philco 38-7 dial lamp - by rghines1 - 02-27-2012, 07:44 AM
The speaker table error?
Philco 70 antenna lead
