IF Alignment 41-290
That slug should have a major effect on sensitivity. Can you see if the slug is actually moving up and down?
Richard
IF Alignment 41-290 - by TFB - 02-11-2012, 10:04 AM
RE: IF Alignment 41-290 - by RGallahue - 02-28-2012, 08:29 AM
RE: IF Alignment 41-290 - by codefox1 - 02-28-2012, 01:17 PM
Re: IF Alignment 41-290 - by rghines1 - 02-11-2012, 11:36 AM
Re: IF Alignment 41-290 - by TFB - 02-15-2012, 08:54 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6927 online users. [Complete List]
» 1 Member(s) | 6926 Guest(s)
