Escutcheon Question For RON Please
I just looked...both sets use bezel 27-4842. So...both use the same escutcheon. However, they use different dial scales. Model 40-160 is a two band set while the 40-165 has three bands.
Re: Escutcheon Question For RON Please - by Ron Ramirez - 02-11-2012, 09:51 PM
Re: Escutcheon Question For RON Please - by Arran - 02-12-2012, 10:44 PM
There are currently 10907 online users. [Complete List]
» 2 Member(s) | 10905 Guest(s)
