Set screw removal
Maybe this is a silly question, but I haven't needed to do this before. The set screws I'm used to dealing with always had a screw slot on the end. These just have a rectangular stub
[Image: http://www.highsierrahosting.com/philco/setscrew.jpg]
Is there a good way/tool to use to back these out? As you can see, access is limited.
-Bill
Time flies like an arrow, fruit flies like a banana
Set screw removal - by billp - 02-12-2012, 04:04 PM
Re: Set screw removal - by Ron Ramirez - 02-12-2012, 07:32 PM
Re: Set screw removal - by codefox1 - 02-13-2012, 04:28 PM
Re: Set screw removal - by Dave - 02-13-2012, 10:11 PM
Re: Set screw removal - by ipwizard - 02-14-2012, 04:44 PM
Re: Set screw removal - by billp - 02-14-2012, 05:26 PM
Re: Set screw removal - by LASJayhawk - 02-14-2012, 07:32 PM
The speaker table error?
Philco 70 antenna lead
