Antenna?
You could build yourself one of these. Four dowels and a door trim block from Lowes, 100' of thin insulated wire, and a matching air capacitor. Any old thing for a base will do. I have rudimentary instructions I can email if you're interested. Google "AM loop antenna" for lots of options. The one on Ebay is junk, don't waste your money.
[Image: http://i863.photobucket.com/albums/ab191...s/la-2.jpg]
Larry
Antenna? - by jlc977 - 02-12-2012, 07:29 PM
Re: Antenna? - by 7estatdef - 02-12-2012, 08:00 PM
Re: Antenna? - by jlc977 - 02-12-2012, 08:12 PM
Re: Antenna? - by Steve Davis - 02-12-2012, 08:20 PM
Re: Antenna? - by rocketeer - 02-12-2012, 09:23 PM
Re: Antenna? - by tpcaz - 02-12-2012, 11:04 PM
Re: Antenna? - by magicclocks - 02-14-2012, 02:02 PM
Philco 91 Tuning Condenser
